He made him review with an electrician, apparently everything is in order, just that he mandates sparkling at the 4 spark plugs at the same time, it is Nafta and GNC. A diagnosis was made and does not mark any fault, I still did not connect to the Scanner, I want to get all the doubts before paying $ 1500 to connect the scanner. If you have any idea what it can be, I would appreciate it very much. I also check the distribution, apparently everything is in order, but they told me that this car has a key on the crankshaft pulley and that it is cut and leave point, but I do not see because I should throw spark at the 4 spark plugs at the same time, if it were so it would only make false explosion or start it would fail, the truth is that I am already crazy, buy an ECU to try if that was the problem but there is still the problem.
