Hello to all the foreros, to see if someone can help me. I have a Ford Mondeo II of 97. A few days ago I began to fail my emergency light switch, made a noise as a false contact, until it has stopped working. The flashes work perfection, but when he presses the breakdown, nothing is done, I suppose he does not make contact. I have checked the fuse, which is the same for the horn and is perfect. You can change only the switch or you have to change the entire intermittent system.
Thank you.
