Good morning, you can help me with this query ...
I bought this 2006 eclipse with manual transmission which had a sound when putting the clutch in the transmission the seller I indicated that it was the pine To point out that on this occasion possibly or the safest did not put oil from the marking in the instruction ..., then to this if the sound was eliminated that was about 2 years ago, approximately 1 year ago a fault which describes it as it was sweep He took it to another mechanic which told me to change the clutch (clutch) and a retain since the clutch area had transmission oil and he gave the patinated failure to the fact that the transmission oil moo the clutch and it was towards which it skated, well, it was changed, but not hard more than 2 months and the fault returns.
How do they know the bahjar and review the transmission generates a considerable expense for what I would ask them:
do you consider that the expense to do is to buy another transmission?
They consider that again to repair the transmission and if so, I require to get another cllutch since the previous one could be with transmission oil?
Or maybe it is a change of oil or something easier to repair or some way of really diagnosing in order to know what the failure causes ...
according to what I describe, if they have doubts I am at their orders.
thank you so much
