, good afternoon, I have a Chevrolet Aveo 2013 that this error came out in the scanner
P0106 manifest Pressure/Barometric Pressure Circuit Range/Performance problemm It is cleaned does not smoke or strange noise in the engine but the idle is unstable and it goes out I appreciate some help ... wealth to all
Hello first I tell you that as something basic you should not replace any sensor only guided by the error code the scanner is only guiding you towards the sector where it is failure. In this case, the first thing is to check the sensor voltages and if they are correct to see the signal that the computer sensor also deliver Revolutions go up you already found the leakage/suction of lucky air
