Good day forum, I expose what happens to me with my Aveo 2009 to see if someone has any idea that it may be happening:
3 months ago I began to notice that the driver's tire was tied (braking) alone after advancing about 5 minutes ... if he pumped the brake when that happened sometimes he managed to take off and continued.
I changed him:
front jaws, front brake hoses, tiles (4 wheels)
I already checked:
master cylinder (works correctly)
brake booster
I purge the system by means of a vacuum pump, starting with the wheel farthest to the master cylinder. When purging the driver's wheel, brake oil is very dirty (DOT3), as with oxide, I already changed the steel line thinking that it can be, but continues to fail.
Any idea?
Greetings!
