Aid. Peugeot 207
7 years 1 month before #53139 by manual-mecanica
Aid. Peugeot 207 published by Manual-Mecanica
The theme is like that. I have a 1.4 2007 partner. The aluminum block was ruined and I am replacing it with a 207 engine that is 1.6 16 valves. I found several problems. Among them the most important so far is the body of butterfly. In the partner the accelerator is mechanical and in the 207 engine is electronic. I wanted to replace the electronic with the mechanic but the body of the partner's butterfly is much smaller. They recommend me. I want it to be mechanical so as not to replace the ECU. Neither the pedal nor anything. Someone knows that mechanical butterfly body could use in a 207 engine or that recommends me. Thanks from now. Greetings
