Stop bulb
16 years 8 months before #4593 by manual-mecanica
Stop bulb published by Manual-Mecanica
Greetings to all the users of this magnificent site, I am new here and then I want to make a petition: someone can give me a manual or tell me how to install the rear stop bulb of a Suzuki GSXR 600 mod motorcycle. 98; I mean this piece that allows you to illuminate the back focus when we stop. I currently have it directly connected and I already got this piece, but I really do not know where or how. I hope you can help me and I appreciate your valuable help in advance.
Greetings!!!
16 years 8 months before #4687 by manual-mecanica
Manual-Mecanica response on the Re: Stop bulb
Normally the bode brake light switch is in the same front brake handle, next to the brake fluid boat box, there must be a piece with two finite cables that are curled at the hand of the handle.
In the case of the rear brake, the brake lever usually has the brake switch attached, so that or pull the switch through a fine grind, or press it when you step on the brake lever, look for the switch surrounding the lever because it does not have to walk away.
Another system that also use some motorcycles is to put the switch on the tip of the rear brake pump, so that it is activated by hydraulic pressure when you step on the brake lever. In that case, the bomb of which two fine corses leave.
Greetings and I hope you find something.
16 years 8 months before #4697 by manual-mecanica
But the rear brake is hydraulic or mechanical if it is hydraulic can be in the brake brake bonb
16 years 8 months before #4709 by manual-mecanica
The GSX-R rear brake is hydraulic, but sometimes the drive of the brake light is not operated by hydraulic pressure, but by movement of the brake lever, case of some quads, for example.
Anyway, I have been asking and they have told me that almost surely the switch is housed in the rear brake pump.
All the best.
