Good to all, I have a Ford Fiesta 1.4 TDCI (F6JB) with a problem in the camshaft sensor. It turns out that after checking wiring and signal with the oscilloscope determined that the sensor was bad because it did not give hot signal. But after changing it, I kept failing, but a different one in this case was what the two -wave crest was communicated so that sometimes the wave instead of square was rectangular. After re -checking the wiring and it determines that this sensor must have come badly and replace it. But the new sensor stops giving signal when it seems, especially when revolutionizing the engine or turning in a roundabout. The funny thing is that when I stop giving signal if I disconnect the connector and plug it back in this time and this time it does not seem to fail when accelerating or turning. I have checked the connector and switchboard pins, the wiring that does not present short circuits, positive, among them and that has good continuity and everything seems correct. That touches me a bad sensor can happen but two is already very rare. The error that usually reports is the P0341. Has something similar ever happened to you? Any suggestion? Thanks beforehand.
