The temperature needle does not move
16 years 8 months before #4637 by manual-mecanica
Hello, my problem is that the temperature needle has stopped, what can you have? And if it is from the temperature sensor that carries the clock where it is located.
My car is an Atlanta Ford Escort of 94
greetings and thanks for your attention
16 years 8 months before #4645 by manual-mecanica
Manual-Mecanica response on the Re: the temperature needle does not move
Hello, for the K Indicas Model I think K is a 16V Zetec engine, if so, the sensor is in the cylinder head by the front of the thermostat, square connector with 2 pins. Almost insurance k is the sensor.
16 years 8 months before #4829 by manual-mecanica
Thank you so much!!!! Indeed, he was saying and from there it was the failure, he is already solved. And forgive for the delay to answer, but until yesterday I had no time to change it.
Greetings
