RENAULT 19 REMOVER LIGHT 19
16 years 8 months before #4710 by manual-mecanica
Light back renault 19 published by manual-mecanica
I would like to know where the reverse 19 makes contact to turn on the back lus, since they do not light. I checked fuses and are fine, well lamp. Current arrives at the fuses but not to the portalámara. I don't think it's a cut cable. Thank you so much.
16 years 8 months before #4719 by manual-mecanica
Manual-Mecanica Response on the Re: Light Reversing Renault 19
Hello, look on the left side in the box you have a bulb disconnect it and bridge it has to turn on the light if you do not have a problem in the cable if it turns on is the luck bulb
16 years 8 months before #4749 by manual-mecanica
The contactor, as the partner says is in the gearbox the first, the exact position is usually in the front or superior of the change. A two -cable connector comes to that contactor, that if the bridges with the contact on the back lights.
The contactor is threaded in the box and to disassemble it, it is enough to disconnect the cables and loosen it. Note, the valvulina of the change may come out, depending on where the sensor located in the box is, you may have to replenish some valvulina, but it is nothing serious or difficult.
All the best.
