mmmmmmmmmm to see Alexandra, we are going to do some tests in your box that must be an axod or axod-e, you have two connectors with many cables one of them is connected to a parking and neutral switch that is a black plastic crescent moon above, this is the one that sends the signal so that it starts only in P and N, this must be aligned in N with a rall. Housing of the box and a rallite outstrified in the aforementioned switch remembers that you must put the lever on N, to focus it you have to loosen the two crescent and alignal screws. Another proof if we remain the same is that you have another connector up where the carter of the valve box is, start your truck and disconnect this connector that the only thing you will see is that the other part enters the box, put any speed and if it no longer turns off that we wait Motor goes out when the engine feels load and this is what would be the distributor called the camshaft sensor, it is located on the distribution chain cover is a black caps like just over an inch of díameter and it has two very small screws if you take it off is a hall collector, but what fails is what is down that it is like the distributor and it carries in the lower part an gear that the tree moves. than removing it and check that I turn freely that I do not know but you have to be careful when removing it since this distributor so calling it has an exact position so I recommend that you put the engine at 0 or PMS, then you remove the plastic sensor and perfectly verify the position of the piece that you will see that it is like a crescent, then before removing the screw that is removed with a 10 mm. Monoblock not to lose the position, already marked everything removes the 10mm screw that is a gunto with a slightly large flat rondana, turn this trunk if you get stuck or feel that it does not work well if you try to fix it, it will not help you much they will never have to put it new and only the agency sells it but it is not very expensive.
If we continue to ask me but give me a little more data from your engine I am Mexican and the engines change from country to country.
Greetings
