Good afternoon Lostmol20, look at the water vapor (white smoke) is normal in cold games, but if it persists with the already hot engine, you have a problem because the water is passing to combustion, now the blue smoke, it is burned oil, but this problem not only occurs by rings, you have to check the seals or guides of the valves the close ones, now the change of rings is usually made once the Cylinders If they did not, you do not take anything out with changing them new, for the white smoke in general with a change of button packaging they look good, but if your car is recalated at some point, you have to check the surface of the cylinder head and the block, in general we talk about a complete adjustment, but so that you leave the doubt of the water, it is enough to remove the spark plugs and see their state.
