Ford Focus Problem 2003
16 years 7 months before #5229 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Focus Problem 2003
correct, but the car turns to you?
If you don't turn on, give it punch in the pump and try if you turn on
16 years 7 months before #5230 by manual-mecanica
The car turns on but when going slowly in a car's tail it seems to go out, such as it does not reach fuel to make it diagnosis and I get an error in the secondary sensor of the pump
16 years 7 months before #5246 by manual-mecanica
Make the hoses reviewed can be some disconnected or broken or the Step by step or the acceleration body sometimes you are given a code but it is not said that it is specifically a piece may be something that motivates that malfunction.-
