VOLKSWAGUEN 1.6 2004 INJECTION MARELLI
16 years 7 months before #5384 by manual-mecanica
VOLKSWAGUEN 1.6 2004 INJECTION MARELLI PUBLISHED BY MANUAL-MECANICA
I have a problem with this because it has an accelerated bone in reling and counter -plates, surely it is in an emergency schedule on the computer, but what worries me is the mechanical point of Ignition, how I can do to control it, it has 9º of progress, but I have to make the computer recognize the piston nº1 so that I load the information well, there is someone who can give me a hand, I want to set it on. in Argentina that on the key with this car.
Thank you very much !!!
16 years 7 months before #5387 by manual-mecanica
Manual-Mecanica Answer on the Re: Volkswaguen 1.6 2004 Injecting Marelli
Good afternoon to point out the National Gol (Argentina) line, you have to search near the battery a black tab with a gray piece similar to a fuse you take the black tab with your hand and remove the gray piece with the engine running it. You are going to notice with the lamp that the targeo is varied that means that injection calculator is working correcting the setting this is the simplest thing that telo can explain. Atte Pacchinb)
16 years 7 months before #5390 by manual-mecanica
When those cars do that oscillation, they can normally be three things an air aspiration by some hose, the air flow sensor, or the step by step, something else the spark plug wires that have once happened to me that I had an irregular minimum and were the cables of sulfated spark plugs changed cables and spark plugs and everything ok.- Check that and make me know, the car of you is the car of you.
16 years 6 months before #5438 by manual-mecanica
I tell you, I put the new step by step, spark plugs of 3 new electrodes, new cables, new detonation sensor, but it continues to accelerate and consume demacious, I no longer know what else to review ...
16 years 6 months before #5439 by manual-mecanica
I thank you, I put it into practice but I cannot put the point well because the car is still suddenly accelerated and it varies constantly ...
