Hello good morning you know I have a Passat 2001 Turbo, Triptronic and there is a somewhat strange problem because I already went with two mechanics and did not rule it and because in the agency it is very consistent, it turns out that the symptoms are at the time of going run The truth takes me out of wave, because the neutral veículo does not make that jaloneo, to which it will be revealed?
