Max Fiesta Failure
16 years 6 months before #5480 by manual-mecanica
Max Failure Published by Manual-Mecanica
I have a Max party that starts well after a mimuto begin to fail cylinders 2 and 3 the injection signal is cut. Then I stop it and start well but in the minute the same. The ignition is fine because I have a sparkle in the spark plugs.:(
16 years 6 months before #5484 by manual-mecanica
Manual-Mecanica Answer on the Re: Fiesta Falla
Surely it is the spark point that is handling the computer, the point is run and the medium cylinders fail, first look at the distributor's lid if it is not spent, if this new one you will have to test it.
