Antiaranque Scenic 99
16 years 6 months before #5541 by manual-mecanica
Antiaranque Scenic 99 published by Manual-Mecanica
Someone can explain to what is due. There is no way to start. A greeting.
16 years 6 months before #5547 by manual-mecanica
Manual-Mecanica Response on the Re: Antiaranque Scenic 99
It is possible that the chip that is in the starter key has been damaged, have you tried another key and does the same?
The anti -theft immobilizer system is in charge of allowing the start of the car only with the recognized key, if you make the bridge or insert an unchanging key, the module does not recognize key and therefore does not allow the start. When this happens, the fault witness or a witness with a drawn key is lit.
To verify the system or program new keys you have to put the scanner. (Renault, Bosch Car Service Workshops AD, or similar).
16 years 6 months before #5550 by manual-mecanica
If the key is by infrared system, fix if the welding of the LED has not broken, if that happens that resold it and probate with the camera of your cell. in the filmmaker's option; Point the key to your cell camera. And look if the LED turns on, now if the key is of the most numerous model that is distrusted and passed to system 2; In that case you have to connect the Scaner and change it again to system 1
16 years 6 months before #5576 by manual-mecanica
Turn off your phone and test sometimes according to the Renault informative can influence the start of the vehicle and review well if that is the defect.-
