Hand brake at Fiat Punto
16 years 6 months before #5552 by manual-mecanica
Hand brake on Fiat Punto published by Manual-Mecanica
I put the handbrake and do not get hooked, get off alone. Someone can guide me about this breakdown, is it easy to repair?
Thank you.
16 years 6 months before #5569 by manual-mecanica
Manual-Mecanica Response on the Re: Hand brake on Fiat Punto
Hello Pocacosa, that problem is revealed to the handbrake comb, its teeth after a while they are recent and weed and they no longer perform the lock, it is unlikely that it is your piola since generally when it is cut it shows in the teencion of the handbrake, that is to say it does not put resistance when throwing it, if that is your case is the piola, but, it is only the comb. Try to throw it up and then carry it towards the right or the left see if it works this is as you see how to change it, not for a hundred it only works little time.
