What are they like?
I am new here in the forum I am about to buy an eclipse GS Mod 99 of the USA as I am reading info about that car I found the Crack Walk and I surhed some doubts
are more or less these
1.- What exactly is this of the crank walk ??
2.- How to know if an eclipse already came out?
3 ..- Is it expensive to repair it here in Mexico?
4.- All of the clipse versions can suffer this problem or the GST and GSX is not ?? although the read that the GST and GSX are still more delicate.
5 And more important can continue working with the Crack Walk ?? Or flat the car Valio mother
is to say I do not want the car to run it, just to walk, well you see an accelerated on a highway to drag a Chevy
6.- As I read the most harmed are those of 4G63t engine the eclipses 99 gs do not bring that engine right?
I
found the version of the engines
is That this is a stupid question that I am going to do but neither Pex 7.- If the GS brings the Mitsubishi Gs Spyder of Mitsubishi \ "q I have read is mitsu to those who come out the crank walk, then my logic makes me think that
the gs 99 are not so given to the problem of the crank GS 99 It will be welcome
thanks in advance
this info about Crack
[Code: 1] Citation:
Originally written by Eclipsejulio
walk
produces
in the 4G63T engines, I had to investigate a little. Installation of the Sigual in its bearings, which results in unequal loads and contact with the crankshaft sensor, in conclusion premature failures in all 4G63t 7 bolts
. Eliminate the
exesive
Walk
circulation
. (Check Engine Light) *RPMS decreases significantly when the clutch pedal is released.
The
clutch does not return to its normal state after pressing it. CRANK WALK very easily INCREASE A MARCATION INDICATOR IN THE BLOCK IN THE FRONT PULLEY, CAREFULLY TAKE
THE
CUANIZ filtration .
Machine
to
6
bolts .
