I have my peugeot 106 1.1 gasoline in 2 cylinders
16 years 6 months before #5725 by manual-mecanica
Well, I have petroleated the engine of my Peugeot 106 1.1 gasoline and I do not get out anything but 2 cylinders; Since the electric coil is either at all than 2, 1st and 4th, does anyone know something to me?
16 years 6 months before #5737 by manual-mecanica
Hello, because you are 100% sure that spark does not reach two cylinders, it is clear you have loaded the coil corresponding to those two.
When oil is oil, the coil must be covered as well as the switchboard and other electric or electronic devices.
16 years 6 months before #5772 by manual-mecanica
Verify first what kind of coil you have, I think that the Peugeot just use a long one for all cylinders, if you snorted the coil 2 that is what sends 2 and 4, now if you only have one check the captor, ahy vehicles that have two captors one for 1 and 4, and another for 2 and 3, they are very rare, but it is also rare that your peugeot Your peugeot what type of coil uses and I see what it can or what it can be, because without that I know, when only the cylinders have a bib all are left without current, check that and let me know.
16 years 6 months before #5780 by manual-mecanica
Hello thank you very much, for your help, in the end it was effectively the coil (Delco), the one that was wrong, I have changed it to another and it goes correctly, a greeting.
