Seat Toledo does not start
16 years 6 months before #5758 by manual-mecanica
Seat Toledo does not start published by Manual-Mecanica
Hello, I have a toledo with carburation (monopunto) that floods the cylinders with gasoline and when the electric contacts of the monopunto are disconnected and stops naturally because the food is cut, some person can give me a clue, the monopunto has changed and remains the same, thank you.
16 years 6 months before #5792 by manual-mecanica
Manual-Mecanica response on the Re: Seat Toledo does not start
You could have a problem at the UCE but first remove the codes as a fault
16 years 6 months before #5808 by manual-mecanica
Visit in this same forum the thread that I posted some time ago with a problem similar to yours in a Toledo 1.8 monopunto like the one you have.
In the thread it also comes how to get the fault codes from the switchboard and what each one means. That is the first thing you have to do when you find an electronic problem because changing pieces without knowing first whether or not they are causing a breakdown does not usually give a good result.
All the best.
www.manualsdemecanica.com/component/opt...iew/id.5401/catid,4/
16 years 6 months before #5837 by manual-mecanica
Hello Megabeat_1, it is right, I take out the codes I have seen in several models and different brands that one of the main problems that give this symptom and that they never take into account is the Temperaura sensor, but Chea the first codes.
