Hello K Tal, I have a problem with the heating fan of this car, no speed works for me, not even the maximum. I have reviewed all the fuses, connections and the fan resistance, but I do not see anything weird, the fan only comes negative, having if you have given this case or you have the electrical scheme of this vehicle.
Hello, as it says short circuit, you must try the direct fan to Vateria to rule out that this is the problem, connect the positive to positive and the negative to negative or dough as you want, it is better with the cables to battery, if you run the fan recently we look Be electro and not thermos, you can't leave it directly, if they work, they burn.
