Ford Diesel Start
16 years 5 months before #6031 by manual-mecanica
Ford Diesel starter published by Manual-Mecanica
Hello K Tal, I would like to know if he has given himself, in a Focus 1.8ddti of the year 2000 and a currier 1.9d of 1998 that sometimes does not start and the diagnostic machine does not indicate anything, only once in the focus indicated the cranker Focus). I thought it is due to lack of compression although that test I have not realized it. Sometimes it does so in cold and sometimes hot and not every day and I have also tried other keys. Well I wait for an answer if Hos has passed. A greeting.
16 years 5 months before - 16 years 5 months before #6035 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Diesel Start
Hi Betis, visit the posts I wrote some time ago about this same breakdown in the Ford (eye, conventional injection bomb, no common rail systems).
www.manualsdemecanica.com/component/oppt...Ew/id.5888/catid.4/
www.manualsdemecanica.com/component/oppt...Ew/id.5860/catid,4/
The Focus is a TDDI, with Bosch EDC EDC VP-30 injection pump controlled by switchboard conventional).
What moving me a little is that the B9A, C9D, C9A, F9A and FFDA engines usually fuck the topic segments when they are used a lot of cold and high of turns, I already had to do one with 60,000 km and I know more similar cases, check the compression of the engine if you can not I screwed the nozzle and made a longitudinal scratch on the needle, the injector enters \ "in egg" in the cylinder head, with the original flange and everything.
Greetings and after trying me if the problem is solved ok?
Latest edition: 16 years 5 months before by .
16 years 5 months before #6069 by manual-mecanica
Question in the Consequently if there is any update of the software of the pump switch on ethos cars made several.-
16 years 5 months before #6101 by manual-mecanica
Hi Betis I had a problem with a focus of these but mine only towards a noise when it comes to starting only one clack repaired the motor start and followed igial at the end obtained for putting a relief and worked
