Generally, the velocimetro is screwed with a Turk a point crown will serve you, in general they are 17, 19, 21 mm measured, but generally these when they fail they do not mark it is not that they mark melting, so you want the problem not this is not in the score Solve the problem, the Scaner will only tell you failure in the speed sensor if it does not do so is the indicator itself.
