Look if the circuit was completely discharged and the entire brake fluid was emptied, for an oversight, it does not happen, you will have to bleed the pump, as long as you are left without liquid, if your vehicle has ABS or a multiplier of force, you will have to bleed this too, this is a small box where 4 can be Way of bleeding is from the most served wheel to the farthest, so the air is not returned. But there is a small problem if you exercised defiance on the pedel at the time of bleeding, it can happen that you decompose the pump, you have to step firm but soft a lot another, one hose to the brake to bleed and the other to the deposit and holy remedy, does everything easy
