Tiida 2009 clutch
15 years 11 months before #8618 by manual-mecanica
Manual-Mecanica Answer on the Re: Tiida 2009 clutch
Hello partner, so you comment on the fault, it can be due to the fact that it has taken air in the system, check the pump and clutch bombin to see if the liquid drips, if so it repairs the loss and then purges the system to remove the accumulated air and keep me aware of what you find.
15 years 11 months before #8634 by manual-mecanica
Look for what you say you can have air in the system, now it is easy to repair with the help of a friend tell him that he pumped three veins the clutch with this foot Pedal is soft all the time and does not clut up unless you pump it this lasts a time, after this time never cluties, let us know how you go with the problem, greetings,
15 years 11 months before #8742 by manual-mecanica
Thanks friend, in effect the system that is together with the brake system took air when the franos liquid was missing and it is not necessary to purge it unless you are in a hurry, the Vá recovering the level as you use it and do not burn Clucht. Just apply the brake league, it's already perfect.
15 years 11 months before #8744 by manual-mecanica
How good to help and thank you for putting your solution like this we help other forists.
