The first thing is to mouth the battery to avoid problems. Then in the F engines you have to remove the engine air filter.
Once this is done, you can access the starter engine to disconnect the battery positive cables and the terminal that comes from the contact key.
With loose cables, the three screws that hold the start to the gearbox envelope are loosen.
The starter motor comes out of the right wheel, behind the wheel.
All the best.
