Failure in Cavalier 1995 2.2 lts
16 years 5 months before #6420 by manual-mecanica
Failure in Cavalier 1995 2.2 Lts published by Manual-Mecanica
I would like someone to help me, the Cavalier is turned on the oil of oil, hot and without accelerating, when accelerating, the directional of the right side does not turn on (it does not blink) and the one on the left side works perfectly, thanks for your help.:(
16 years 5 months before #6432 by manual-mecanica
Manual-Mecanica Answer on the Re: Failure in Cavalier 1995 2.2 Lts
The oil light usually occurs due to the evil of the oil pump that does not lift the precion that must, recently posts a Toyota Corolla that happens to him the same, the light if everything turns correctly, that is, the shield indicators turn on you, the problem is in the instrument panel you disassemble it and change the ampoule or bulb that corresponds and that's it. Why do the outside light work, right?
