Good, you will see myself to buy a sinister to use donor. It is a GTI GTI 2.0 16V golf. The car in question overturned and swallowed about 1 liter of oil.
When I went to see him we tried to start it, he did it but he fell at 3 or 4 sec., So they tell me it is possible that having started it had hooked and folded cranks.
In the best case they tell me that spark plugs would have to be removed and giving the contact to expel all the oil from the cameras and I suppose that air filter should be changed and the admission is clean, right? Then I would have to fill with oil so that it has not already done so)
placed in the worst will have folded cranks and I do not know if in this case its repair will be worth it.
Can you have something else due to overturn? Should I look at something else?
Thanks in advance. All the best
