How do I try the Nissan Sentra gas pump
16 years 4 months before #6858 by manual-mecanica
How do I try the Nissan Sentra gas pump published by Manual-Mecanica
My abant does not turn on, I suspect the gasoline pump ..
how do I try it?
16 years 4 months before #6870 by manual-mecanica
Manual-Mecanica Answer on the Re: how do I try the Nissan Sentra gas pump
You have to check the pressure of the pump if you have it, the simplest is to disconnect the manger or line and open it to the swicht must come out with pressure the gasoline, it may not be going current to the lucky pump.
16 years 4 months before #6878 by manual-mecanica
I have VW Jetta III, it changed trans. Engine Speed ​​Sensor Sensor G28-IDLE RPM, continues to do the same problem, does not make the drive camvios, only manual (automatic) I do.
16 years 4 months before #6879 by manual-mecanica
Look at the Nissan Sentra, just like all Nissan have problems with the captor magnets, verify if there is a current in the spark plugs or cables, as for the pump I do not think that aya problem with it anyway looks for the hose that leaves the pump towards the injection system, disconnect it and give it a touch of start if the pump comes out, the precion you will not be able In general, vehicles start bad and stop, but start, I lean more about the current.
