Caravan 98 sensor
16 years 4 months before #6946 by manual-mecanica
Caravan Sensor 98 Published by Manual-Mecanica
!! What do you recommend? The MAP sensor does not work, take it to scan to two different places and marked me the same fault is well to buy it used or new? And where GDL. I buy it?
16 years 4 months before #6960 by manual-mecanica
Manual-Mecanica Answer on the Re: sensor for caravan 98
You buy it used just make sure that it works correctly, now the MAF do not spoil easily, which the Scaner said fails in operation or wiring failure, usually coples and the tracera connection is the one that fails, a czech before buying, you want the pins do not have good contact.
16 years 4 months before #7003 by manual-mecanica
One thing is the MAP and another thing is the MAF that is what you have
damaged if you can get one used to try to do it and then buy a new one and you mount it remembered that the MAP is a sensor that works by depression and the membrane could also be damaged, that if it controls well the sensor elbow that is the same the same
