Cabling doubt
16 years 4 months before #6948 by manual-mecanica
CABLE PUBLISHED BY MANUAL-MECANICA
Well, my question is about the type of cable that I must use. I want to reinforce the physical land of the battery, the alternator cable to the battery and the earth. that is Big Three. This due to Ak Akabo to put a sound amplifier.
Does the cable have to be used for the automotive audio equipment or did not open a problem with another but of the same driving section?
According to my considerations, I did not open a problem by K K is used for the current for the amplifiers, it is to defose just because it is more flexible, is it not like that? Thanks in advanceB)
16 years 4 months before #6961 by manual-mecanica
Manual-Mecanica Response on the Re: Wiring Doubt
You are right only the flexibility of the cable is the one that changes, of course that being more flexible protects a little more against the cut of the same, now the cables depends on its grossar according to the work they do, a very thick cable is not necessary, as of battery, but not as thin as parallels of Parlante, with cable of 10 0 3/4 you have plenty.
16 years 4 months before #6965 by manual-mecanica
Ok thanks, I just had the thorn of being right. Now that I know that it is so to work it has been said.
I had already selected the cable caliber taking into account what I am going to use.
: Cheer:
16 years 4 months before #7002 by manual-mecanica
There is a table of what type of cable or rather the thickness of the cable that you must use according to the distance that you must cover and according to what consumption has the separate cable I remind you that the cars carry a special cable that resists more at temperature and are more flexible than the cables used at home.-
