Luz Check Engine
16 years 4 months before #6999 by manual-mecanica
Manual-Mecanica Answer on the Re: Luz Check Engine
They made you the diagnosis of the car and that it came out as a defect, apart from those cars if it has a defect they do not do the auto reset is the recorded error, tighter to reheat makes you some other defect, explain a little more to see, check how much the alternator is loading you and if the battery in what conditions it is.-
16 years 4 months before #7006 by manual-mecanica
Hey Viejo now that you mention it I think that the battery is no longer very good because when I leave the radius on with the car off C quick download, will it have to do with that too ?????
I mean, I have to take it to review the computer ???
16 years 4 months before #7030 by manual-mecanica
If it would be the best because not all computers enter the Asian cars system, check the oil levels, it can be some low level too.-
16 years 4 months before #7032 by manual-mecanica
Old oldssss tried to remove the negative terminal of the battery and the light of check Engine I went out I went to try it and everything well as 1 hour later the light C turned again, the problem is this that I went to fill fuel because it is empthy and when I turn it on the car I did not match me and came out a lot of black smoke by the escape Little more and a little more, and
it was already the fuel and indeed it was super too ,,,,,,,, help
16 years 4 months before #7043 by manual-mecanica
Hello. of relial clean it (take it out of your pig) the temperature.
