Jetta 99 Aut Board
16 years 4 months before #7096 by manual-mecanica
Jetta 99 Aut Board published by Manual-Mecanica
Hello good morning, I would like to know if anyone knows how to fix a Jetta Board auth.
16 years 4 months before #7107 by manual-mecanica
Manual-Mecanica Response on the Re: Jetta 99 Aut Table
Well, take that part of the board, and check all connections.
that there are no loose, or peeled cables
or some false contact.
luckB)
16 years 4 months before #7129 by manual-mecanica
I think the same disassembles the board and clean it checks what cables and connectors, the earth and cylicone can be very harmful
16 years 3 months before #7187 by manual-mecanica
Something similar happened to me. It is the "Crazy Board" syndrome. You must disassemble the board and set all connectors ...
greetings.
16 years 3 months before #7190 by manual-mecanica
Disassemble the board completely and check in the scheme if you notice a cold welding, that is, it looks like it also checks whether any cable is released in the temperature or oil sensors or sees if any connector is disconnected in the engine that can be creating a false reading of the sensorred signal that the boards are also centralized and need the fluid information of everything.-
