Problems with central aerators result megane
16 years 4 months before #7151 by manual-mecanica
Problems with central aerators result megane published by Manual-Mecanica
Hello I have a problem with a Renault Megane 1.9 130 hp of 2007.
When I put the heating it makes me a noise inside the central aerators, I do not know what is due and I would like opinions about it and how I can repair it thanks
16 years 4 months before #7156 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Central Aerators Result Megane
Hello, try by disarming the forzator and lubricating the insurance bushings is full of dirt and draws the antipolen and changing it or insurance torch will be solved
16 years 4 months before #7169 by manual-mecanica
Hello partner and thanks. Do I have a small problem the forzator to refer to the aerator disassembled? And antipolen filter where it is. Thank you very much again
16 years 3 months before #7192 by manual-mecanica
Calmate, first of all your car has an electronic air conditioner or has normal air conditioning, because then it is also the step by step that moves the air distribution cover, which is blocked and if so there is little to do after what type of noise makes you, explain a little and then we will see what it can possibly be.-
