Good, look at the tireless expense of the tires, it usually has very short explanations according to where you find wear, if you wear out in the bearing vanda, that is, in the center it is excess of inflation (air filling) if spent on the two banks is very little air, if you only spend an edge it is a alignment problem, if you spend jums, that is when you peel the orange shock absorbers, it is always good to check the alignment to be sure that they will not be spent. If you have it with wheels, see that the laughs are worthy.
