Regulation of valves in Nissan B11 engine
16 years 1 month before #7727 by manual-mecanica
Manual-Mecanica Response on the Re: Regulation of valves in Nissan B11 engine
For Europe, Sunny B11 Motor 1.5 Motor code (E15) The exhaust and admission valves are regulated at 0.28 mm, but I suppose the regulation has to be the same for everyone. This information is taken from the Autodata database. Although my specialty is the German vehicles I hope to be able to help you in anything else, I love my profession and I enjoyly enjoyed solving some problems discussed in this and other forums.
I hope it serves you report greetings.
16 years 1 month before #7730 by manual-mecanica
Look if the car is already recommended to give you 25 and 30, or failing that if they sound a lot 30 even, but I believe that with 25 and 30 you will walk well.
16 years 1 month before #7733 by manual-mecanica
That engine carries 0.28 mm valve light and regulate at normal operating temperature, that is, hot a hug and luck.
16 years 1 month before #7736 by manual-mecanica
Friends, I am very grateful for the information and the help provided since with this a pricing in the rapper of ships (only as a hobbi) can advance and also help others that are also starting. I want to tell you that I am an industrial electric and I dedicate myself to automation, so any help in that area would be delighted to help everyone, I perfectly understand that the site is not about this but for now that could be my contribution again thanks and cordial greetings from Pto Varas
16 years 1 month before #7742 by manual-mecanica
How good that you can use the information, but how did you mention that you are not a mechanic, I have a doubt, do you know how the babbles are regulated? The order and crusate valves?, well if you need more information just ask you to help you with pleasure, and how to find a compatriot aca sauldos from Coquimbo Chile.
