Good to all.
As I commented on the statement of the message I have a problem with the light of the vehicle engine electronics from the suggestive day to get it new from the concessionaire.
As not Opel has failed to fix it and less solve it.
The problem arises (not always) with the normally hot engine, when you accelerate to change the gear to about 2700 tours of the engine, the motor electronics lucecita is turned on and the turbo is deactivated.
We have proven several things in the engine as vacuum tubes. Different electronic pieces in case they fail, I have lowered the turbo pressure, I have checked the cables of the Lambda probes in case they are cut, but nothing we continue with the problem. When the computer always gets the same turbo failure.
I'm already desperate I don't know what to look at him.
I would appreciate if someone could advise me on the subject.
In case it serves as information, the car has a speed controller and the rectified engine to reduce the famous high oil consumption with which they took this engine on the market.
Thank you.
Patxis
