TACOMETRO INSTALLATION
16 years 3 weeks before #8147 by manual-mecanica
TACOMETER INSTALLATION PUBLISHED BY MANUAL-MANICA
I want to install a tacometro in my 2002 car that does not have it, so I request support regarding the information that guides me to install it, thank you.
Greetings
16 years 3 weeks before #8148 by manual-mecanica
Manual-Mecanica Response on the Re: Tacometer Installation
Hello look that is very easy there are mechanical or electrical tacometers for you advise you an elctric which connects to the negative of the ignition coil and takes it as a signal, they also bring a positive one which is for 12v directly and preferably connect a fuse which must bring the tapervolutions.
greetings
16 years 3 weeks before #8166 by manual-mecanica
The truth is that it is as the partner says, but Hojo because on occasion they can produce problems because you do not fix the one you have damaged.
16 years 3 weeks before #8174 by manual-mecanica
Thanks for the data, I will apply them.
Greetings
16 years 3 weeks before #8175 by manual-mecanica
What happens is that the car does not bring tacometro and that is why I want to install one.
Thanks for the information
