Cooling system Problem 2005
15 years 11 months before #8698 by manual-mecanica
Problem with Cooling System Plate 2005 Published by Manual-Mecanica
I have a problem with the functioning system of a 2005 Nissan Platina, the car is lowering the level of water gradually not suddenly, and I think that for the same I cannot find a leak, someone who can help me finding that can be causing the loss of water?
15 years 11 months before #8703 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Cooling System Platina 2005
Friend If the low water level and you can't find visible leaks I advise you to check the oil lid and make sure you are not emulted, if you have it broken the blanket packaging, you can also fix yourself if the exhaust boots a lot of water bass.
