Chrysler Neon Model 97
15 years 11 months before #8738 by manual-mecanica
Chrysler Neon 97 Model Published by Manual-Mecanica
Hello everyone: to see if you can help me please, I have a neon model 97, whenever I want to start, when I give contact you hear an electrical noise and then start, well, now it does not do it and how it is to spider it does not start. :(
15 years 11 months before #8740 by manual-mecanica
Manual-Mecanica Response on the Re: Chrysler Neon Model 97
The most surely the pump, a fuse check and in case of being ok measure voltage in the pump connector that is under the rear seat.
15 years 11 months before #8741 by manual-mecanica
I think the only electrical noise it does is when the pump loads, take out the rear seat I think this Ally and check that works, if it does not check the fuses and the pump relay.
15 years 7 months before #10624 by manual-mecanica
How much is the pump voltage? The bomas of the neons have the same voltage?
15 years 7 months before #10634 by manual-mecanica
12 volts all pump model
