Failure when fuel loading in Ford Focus 2000 Aut
15 years 11 months before #8748 by manual-mecanica
Failure to load fuel in Ford Focus 2000 Aut published by Manual-Mecanica
Hello my name is Jovanny and I have a Ford Focus 2000 Motor 2.0 SPI, because the fault is that in the gas station when I take fuel when I turn on the car this goes out .... I turn it back again and go out ..... The third attempt ignites it a little and it is working well !!!! ...................... This only happens to me when fuel, the car does not fail me. Also when I go at high speed I feel that the car pulls but only at high speed.
Take it to the mechanic to change the fuel filter and wash the gasoline tank ............. the car after that leads it to fill with fuel and the same thing happened to me although at high speed it is no longer pulling !!!!!
What could be what goes out to 2 times every time I take fuel before leaving the gas station ???????
15 years 11 months before #8752 by manual-mecanica
Manual-Mecanica Response on the Re: Failure to load fuel in Ford Focus 2000 Aut
The most surely the fuel pump must have a defect cable that moves fuel and stops contact.
15 years 11 months before #8763 by manual-mecanica
Better take out the injections and send it to clean up your problem, you pass your cases and those cases are delayed to start and go well later in acceleration greetings
