The FIAAAT STILO ADDRESS DOES NOT WORK
15 years 11 months before - 15 years 11 months before #8753 by manual-mecanica
PUBLISHED BY MANUAL-MECANICA DOES NOT WORK
Hello, there is no works for me, the melting direction is hard as a stone and then the battery died I thought it was from the battery but I have changed it and it remains the same also after changing the battery a light is turned on in the control panel with a red battery that means I need help please please
Latest edition: 15 years 11 months before by .
15 years 11 months before #8758 by manual-mecanica
Manual-Mecanica Answer on the Re: The FIAAAT STILO ADDRESS DOES NOT WORK
Look for what you say you have problems with the strap of the alternator of AHY the battery light on and if the belt is the same for the direction it is for this reason that it is hard since the pump does not work, now if they are separate straps that I do not believe, the problem can be the damper, but I think that with the tense of the belt you will be well check it and warning, the tensor can be released.
