Honda Civic 1996 Automatic
15 years 11 months before #8760 by manual-mecanica
Honda Civic 1996 Automatic published by Manual-Mecanica
Hi Foristas, I tell you I have a Honda Civic 96 automatic, carburado, and the Damper bolt is released and turns the pulley until it comes out completely, now rectify the tip of the crankshaft and take out the start to bring the steering wheel, I gave it 70 pounds of squeeze to the torque and work properly two months, there In a correct diameter in case I had axial game, that you think it can be the problem, it may be that the golilla is on the wrong side that is to say with the inverted edge? They think please.
15 years 11 months before #8762 by manual-mecanica
Manual-Mecanica Response on the Re: Honda Civic 1996 Automatic
Well friend I think that we always handle different terms because of our nationality, I think some images would come well (if it can be clear) but it has happened to me on some occasions and what exhausts is to clean well both the screw thread and that of the axis, because it may be that somehow it is reaching oil, then I put that blue liquid called Threadlokers torqueo and no longer loosen again.
15 years 11 months before #8767 by manual-mecanica
Thanks friend, I didn't want to put glue or liquid but I think there is no other option, thanks.
