Help !! The brakes fail me.
15 years 10 months before #9207 by manual-mecanica
Manual-Mecanica Answer on the Re: Help theme !! The brakes fail me.
Hi Palben, when you change the tapes and rectify the bells tell them that they put you soft tapes raybestos or similar, they stop much better and do not damage the surface of the bells and although they have a little less lasting it is worth it because they do not squeak, a hug.
15 years 10 months before #9225 by manual-mecanica
The truth is that any synta speaking will serve you, it depends a lot on the materials so that this does not happen, in reality the brakes are not a big problem to the harme and disarmament, in any case if you revolve the hard noise will go, and as appaCce disappears, there are no longer one of the old ones that were composed of asbestos since as the material is toxic remedy
15 years 10 months before #9234 by manual-mecanica
Thank you very much Jal for the data: Cheer: . A hug too.
Luck.
15 years 10 months before #9235 by manual-mecanica
Thank you very much Karma too: Cheer: . A hug.
