Electroventilator
15 years 10 months before #9008 by manual-mecanica
Electroventillaor published by Manual-Mecanica
Good in electrventilator, I disassembled it and put new coals and before installing it, he tried the battery directly and works well, it turns out that when riding it and putting all his cables how the fuse was burned the car is a Fiat one year 2001, can an electro -ventilator in short work well directly direct from the battery? I tell you this because before lowering the electro -ventilator everything was normal the problem arose when I disassembled and put the new coals to the electro thanks for your help.
15 years 10 months before #9010 by manual-mecanica
Manual-Mecanica Response on the Re: Electrovillator
Hello partner, look at the connections well because you can have a mass cable, did you connect everything like that it was before? Won't you have the positive of the Electro to Reves? Look up by praying the engine live if you turn in the right direction and greetings.
15 years 10 months before #9015 by manual-mecanica
An electro in cut is always in court, check the connected ahy to be the problem.Iquisas you were bad the electro and the cables were invested.
15 years 10 months before #9016 by manual-mecanica
Why do you work well right?
15 years 10 months before #9022 by manual-mecanica
Disarm the electro -ventilator again and apparently everything normal I put its 30 amps fuse the electro is activated but at the minute more or less of being worked, it burns the fuse and a half that melts the plastic of the fuse please, please if someone in the forum can give me a solution or will have to mount a new electrventilator? but anyway I would like to know the opinions of you. On this electro -ventilator to which the fuse is burned if it works normal, that is, it starts strong
