Kango HDI injection failures
15 years 10 months before #9009 by manual-mecanica
Kango HDI injection faults published by Manual-Mecanica
Hello Friends of the Forum I have a Renault Kangoo that starts and is perfect but when you want to step on more than 2000VUECAS, the failure light is turned on in the board and it is ironed as if the central is in emergency. You disconnect the terminal and return everything to normal, as long as you do not accelerate it strong you have to drive it without stepping on it if it does not iron again. If anyone knows for starting, I would appreciate it. It is HDI Mod 2005. A hug to all.
15 years 10 months before #9011 by manual-mecanica
Manual-Mecanica Answer on the Re: Kango HDI Injection Failures
Hello turbine, to start check the air filter that is not covered luck and greetings.
15 years 10 months before #9017 by manual-mecanica
Friend, as you look at the Check turns on to warn of an overwheel for the amount of combus, check the electric pump to rule it out, but your problem reveals to be in the pump has a high valve inside and this is the one that fails, since it carries a micro filter is covered.
15 years 10 months before #9018 by manual-mecanica
Saves could check the return of the injectors also give problems in those models.
