Ssangyong Islana
15 years 10 months before #9132 by manual-mecanica
Ssangyong Islana published by Manual-Mecanica
The speedometer of a Ssanyong Islana Elite went crazy and scarce the needle passes by and brakes against the zero handle. Does anyone have an idea that it could be and how to solve it? I already tried the board and in another vehicle it works well.
Thank you
15 years 10 months before #9149 by manual-mecanica
Manual-Mecanica Answer on the Re: Ssangyong Islana
If it is with piola your ssan check that is not touched, or loose of the box anchor, if it is electric check that the connectors are clean and the body of the velocimeter free of garbage, you warn me that it happens
15 years 10 months before #9159 by manual-mecanica
It is not Piola, it is electric.
The connectors are clean and the board in good condition because we tried it in another SSANG and it is fine.
Could it be the cash connector that has been badly placed? Do you know what type of fitting does it have to work?
Thank you
15 years 10 months before #9163 by manual-mecanica
The most caused thing is that the fault is in the connector of the board itself, the problem I do not know that board if it tubed it in the hand could help and check it but so, I can only tell you that the problem is in the board connector.
