Help with a Neon 2.0
15 years 10 months before #9162 by manual-mecanica
Help with a 2.0 Neon Published by Manual-Mecanica
Hello everyone I would like to help me with a problem that I have with a Dogde Neon 2.0 Model 1996, the problem is that it does not send the current of the coil to the coil and the fuses of fuses and relays and I find nothing abnormal, do not send spark to the spark plugs. Someone could tell me that I could check. thank you
15 years 10 months before #9166 by manual-mecanica
Manual-Mecanica Response on the Re: Help with a Neon 2.0
Look Technigarage, the problem is different if current does not reach the spark plugs or the coils, if the problem is that it does not reach the spark plugs and if the coils, the problem is the coil (s), if the problem is that it does not locks the coils, then it is the fault of the magnets captors or known as the crankshaft sensor of the crankshaft, in some vehicles they are uvicated in the cams. Vehicle does not have this type of sensor you must have anything else on, because the computer does not take care of that but only in the starting phase. If they have the post -lunch of scanning it, you have problems.
15 years 10 months before #9167 by manual-mecanica
[/Ihola Mira can be the stroke sensor but must check some disconnected land or if you have scam you save work
15 years 10 months before #9168 by manual-mecanica
Look I had a problem with a mitsubishi eclipse, that if you know use the same computer as the Dodge Neon, and my problem was equal to yours, the first thing I did is that I have a scanus and if the scanner does not throw me any problem, it is definitely the computer, now the computer uses a small interdo That piece, the best try another computer and tell me.
