When I turn on the Berlingo, it also turns on ..
15 years 10 months before #9176 by manual-mecanica
When I light the Berlingo, it also turns on .. published by Manual-Mecanica
When I turn on the Berlingo, the heating fan is also turned on. This did not happen before, from one day to the next it turned on and I can not regulate it anymore, it is always to the fullest. I don't want to disconnect it since the windshield could not stop. Does anyone know what should I do ???? THANK YOU..
15 years 10 months before #9179 by manual-mecanica
Hello friend, look if I stuck the relay, luck and greetings. www.manualsdemecanica.com/components/co.../emoticons/smile.png
15 years 9 months before #9263 by manual-mecanica
You are right, verify the relay of the heating equipment, because they are usually stuck, or verify that the relay does not arrive continuously, because the switch may be broken, and qde in direct contact, if you do not fix if not Qdo Kn positive direct, greetings and warn what happened.
